My car heats up my legs from inside [Accord 2003]
Old May 22, 2015 | 10:34 AM
The steering shaft sleeve and cap are about the largest hole in firewall. Failure to reinstall these would likely allow heat to enter cabin.
See attached picture. This is from a TSX manual that would allow copy/paste function, however Accord part appears to be identical.
It would be unlikely for the shaft sleeve to be removed as it is not split. More likely the cap is missing.
File Type: pdf
Old May 22, 2015 | 11:51 AM
mikebuddy's Avatar
Thanks alot, tomorrow is saturday, i will personally check this out. to know if the cap is tightened because i know it is there.
I will give you feed back.
Old May 22, 2015 | 01:12 PM
Prospector's Avatar
The manifold is on the firewall side of the engine compartment.
A heat shield is merely a suggestion... Of course, the engine does create heat, however extreme heat is given off by the exhaust system which includes the manifold. All cars have heat shields placed at various locations to deflect the heat emitted away from the cabin
halfmoonbaby
Jan 27, 2013 06:30 PM
Sundevil81
Nov 8, 2012 07:56 PM
moziz
Jul 20, 2012 09:23 PM
sall
Aug 20, 2007 10:22 PM
