car over heats in park
Old Aug 19, 2007 | 06:49 PM
sall
Default car over heats in park
I am having a problem with my 1998 honda Accord. The engine stays cool when driving normally but as soon as I put the car in park the radiator no longer kicks in and it slowly begins to overheat. Im not sure what could be the problem. It doesnt make sense to me because I dont see why the radiator would run differently if in park?? Any help would be appreciated. Thanks
Old Aug 19, 2007 | 07:29 PM
smaglik's Avatar
Default RE: car over heats in park
check your cooling fans. it sounds like they are not turning on, since there doesnt seem to be any air flow when you're stopped.
Old Aug 20, 2007 | 09:27 PM
sall
The fans turn on only when the car is actually driving. When Im in park or not moving the fans do not turn on. It doesnt really make sense to me. Im not sure why it would matter if the car is moving or not in order for the fans to turn on???
Old Aug 20, 2007 | 10:22 PM
Are you sure they run when driving?
Normally they should only run when stopped because driving (even 15mph) pushes plenty of air thru the radiator to keep it cool.
Follow the lower radiator hose to the thermostat housing on theback of the engine. There's a 'sensor' on the thermostat housingwith a 2-wire plug. Unplug it & jumper the wire with a paperclip. Key on, that should make the fans run. Post back after you try that.
edit...
Oops; I forgot to ask what engine. What I said is for a 4-cylinder. I don't know where the fan switch is located on a V-6.
mikebuddy
May 22, 2015 01:12 PM
Cjohnson700
Mar 29, 2013 06:46 AM
Sundevil81
Nov 8, 2012 07:56 PM
moziz
Jul 20, 2012 09:23 PM
campervan12000
Jun 15, 2011 07:23 AM
