ATF Change
Old Aug 19, 2007 | 08:44 PM
JFS321's Avatar
Default ATF Change
I am wondering if once you drain the transmission new fluid is added through the dipstick. The manual doesn't say where to add the fluid, and I am afraid it may have to be pumped in (?). I am not doing a flush, just a change as described in the factory service manual. Thanks.
Old Aug 19, 2007 | 09:31 PM
patpatpat's Avatar
Default RE: ATF Change
Fill it from the dipstick hole. You will need a long neck funnel
Old Aug 20, 2007 | 01:21 PM
00AccordLX5spd's Avatar
Registered User
ORIGINAL: patpatpat
x2
Old Aug 20, 2007 | 09:33 PM
JFS321's Avatar
Thanks to all. I had a new transmission put on several years ago, and not at the Honda dealer. The service manual says Dexron II will work, so I am using AdvanceAutoParts brand fluid that is compatible with Dexron II-IV, etc...should that be okay?
Old Aug 20, 2007 | 10:27 PM
Lots of people have reported harsh shifting & other things with non-Honda brand fluid. I've only used Honda fluid so I can't say firsthand.
Old Aug 20, 2007 | 10:54 PM
deserthonda's Avatar
dexron III will work ,, but i would strongly reccomend Honda ATF-Z1 ,, it is a bit more expensive but well worth the money ,, You will need 3 qts for a drain and refill and yes you do fill it from the dipstick hole as it was adviced by other members
moey
May 22, 2011 10:43 AM
Rainy
Sep 29, 2009 05:26 PM
craigsig
Nov 6, 2008 05:36 PM
dejavustuff
Jan 14, 2008 12:14 PM
choffman41
Mar 3, 2007 02:48 PM
