My Car Is Squealing
Old Jun 28, 2011 | 08:54 PM
HondaUser123's Avatar
Default My Car Is Squealing
Car squeals/high-pitched whine upon startup in the morning, goes on while I drive -straight/turns- for about a minute then stops (when the engine is warm?).
If I idle the car on startup and turn on the AC- squealing begins and stops as soon as I turn off the AC.
When I start up the car at night, there is no squealing.
Is this a problem with my A/C belt? If so, how should I fix- tighten/replace?
I have had this problem on and off since this past winter, it has not gotten to the point where it will happen every day.
Not sure about Engine Size... How do I check? (Misplaced my owners' manual.)
Old Jun 28, 2011 | 09:00 PM
Tek310's Avatar
you have a 1.7L 4 cylinder.
you will need to replace your belt. that would most likely be your problem
Old Jun 28, 2011 | 09:11 PM
Google ZSTZdTAB_As
This is a video from ericthecarguy on belt inspection. It could be a bad belt and/or tensioner.
Old Jun 28, 2011 | 09:36 PM
Which belt? I went to the dealer and they tried to sell me the timing belt, AC belt, and one other one (Power Steering?). Is it easy to replace? In terms of car work, I've only done tire swaps (with rims), brake pads/rotors, oil & transmission changes, windshield wiper blades. I have a Chilton's Honda Civic/Accord '01-'05, but it's kind of confusing when I look under the hood. If there's a good video of how to do it, that'll be great. Thanks for the help!
Old Jun 28, 2011 | 09:47 PM
Tek310's Avatar
i would change the ac belt and power steering belt. there should be a drive belt that is connected to your crank pulley. im not fimiliar with the D17 engines
im guessing the ac belt is the one that runs with the crank and alternator
Old Jun 28, 2011 | 10:06 PM
I'll go pick up those two belts and see if I can get my friend to help me with this little project. Any videos/advice would be appreciated.
Old Jun 28, 2011 | 10:44 PM
Tek310's Avatar
your manual shpould have step by step instructions. not any vids on youtube as i can see.
this is a accord forum, so i dont expect much help here.
on my ladies cavalier she has a single drive belt that turns everything annd is as simple as loosening the tensioner and slipping the new one on and releasing the tensioner
Old Jun 29, 2011 | 05:47 AM
piggylover1985's Avatar
Most dealership will sell you anything to get the money, some people call them stealership, and many cases they don't even do that good of a job.
Old Jun 30, 2011 | 02:31 PM
Randy367's Avatar
Same problem here on my wifes 93 accord. Will change the belts and see if that fixes it.
ldeffinbaugh
Jun 22, 2014 10:25 AM
jill hughes
Apr 3, 2011 08:34 PM
forcefx
Aug 21, 2007 10:40 PM
paul_doors
Dec 1, 2006 02:09 PM
bill3_us
Sep 19, 2006 04:37 AM
