My hand brake light stays on when hand brake is not engaged
Old Mar 27, 2012 | 10:08 PM
DannyJdm's Avatar
Default My hand brake light stays on when hand brake is not engaged
I have an 01' accord 4-dr 125,000 miles...and for a while now almost everytime I start my car the hand brake light stays on when my hand brake is not engaged and then randomly turns off while im driving...and this just started today my right turn signal blinks really fast and my left turn signal blinks normally...Does this happen to anybody else? And what can it be?
Old Mar 27, 2012 | 10:34 PM
crispin's Avatar
ok you have 2 different issues
1) There is a switch on the ebrake. You will need to pull the center counsel to get to it. It is shorting out. You can try cleaning it but me I would just cut the wire going to it or pull the connector off of it. It is not needed for anything.
2) you have a blinker bulb out that is why it is flashing fast. Put the blinker on and check out the front and rear, you will see one is not working. Replacing the burned out bulb will fix the problem.
Old Mar 27, 2012 | 10:56 PM
I agree with crispin, you have a turn signal bulb out. That is the way the car warns you that a turn signal bulb is burned out.
I would not cut that switch for the e-brake. Check your brake fluid level. That can cause the e-brake light to turn on. The float may be stuck in there as well.
Old Mar 27, 2012 | 11:49 PM
Good information men..Thanks
Old Mar 28, 2012 | 08:03 AM
DannyJdm's Avatar
Yeah my turn signal bulb was out.Im going to try the E-brake thing today
wnbasac
Apr 25, 2014 06:38 PM
lecompte51
Jul 3, 2013 01:38 AM
MessAround
Jan 1, 2012 09:01 AM
scott
Oct 8, 2007 05:38 PM
98accord98
Sep 8, 2006 01:25 AM
