MYSTERY: Tail Light dead, fuse & bulb ok
Old Jan 24, 2011 | 12:34 AM
forindooruseonly, you should start your own thread, so it is not as confusing.
In both cases, you should use a volt meter on the bulb socket to figure out if you have voltage or ground.
The non-black wire should get 12V when you hit the brake pedal to body ground (use a known good ground like any bare metal bolt you can find). If you have voltage, check for ~zero resistance from the black wire to that ground that you used before.
Old Apr 19, 2011 | 12:08 AM
wh0uis's Avatar
BUMP
i have the same issue....I have a Honda Accord EX 1994'. The tail lights dont work. However the Reverse light and blinkers work. How much would it usually be to fix thhis in a shop?
alyssapie
Aug 13, 2012 10:58 PM
Lenno
Jan 29, 2012 07:45 PM
ohill1981
Jun 16, 2011 11:48 PM
apchar
Apr 14, 2008 02:40 AM
sskkf
Jan 19, 2007 04:23 PM
