Need advice on install of Heat shield for 05 V6
Old Nov 26, 2014 | 01:16 PM
tommoran2's Avatar
Default Need advice on install of Heat shield for 05 V6
I have an 06 Accord V6 which has a rattle in the heat shield engine cover.
Dlr wants 300 in labor to R/R the 30 dollar part.
Any advice on DIY for this would be appreciated.
Thanks Tom
Old Nov 26, 2014 | 01:23 PM
Your thread has been moved. Please do not post help questions in the DIY section. That section is no longer used for help questions.
Please read the separate Announcement and sticky posted by the Administrator, right above where your thread was originally posted.
Old Nov 26, 2014 | 03:16 PM
Not sure what heat shield engine cover you're referring to. There is a plastic engine cover on top; but, it does not serve as a heat shield.
For a V6, there are three convertors. Are you referring to one of those?
http://www.hondapartsnow.com/diagram...-v6-465599.png
http://www.hondapartsnow.com/diagram...-v6-465482.png
Old Nov 26, 2014 | 03:31 PM
tommoran2's Avatar
Default here is the part
This is the part
44517-SDB-A00 | COVER, HEAT | Honda Replacement Part
Old Nov 26, 2014 | 04:30 PM
That's the heat shield for the intermediate shaft.
There are 3 bolts that hold the heat shield onto the intermediate shaft. But, the service manual shows Exhaust Pipe A (aka J-pipe) being removed first to access it. (See attached images.)
You may be able to use swivel sockets, etc. to get to the bolts without removing the J-pipe.
This other thread shows the drive shaft, intermediate shaft and shield removed. They make no mention of the need to remove the J-pipe.
How to pop out passenger side axle? - Drive Accord Honda Forums
Attached Thumbnails Need advice on install of Heat shield for 05 V6-heat-shield-removal.jpg   Need advice on install of Heat shield for 05 V6-heat-shield-install.jpg   Need advice on install of Heat shield for 05 V6-exhaust-pipe-j-pipe-.jpg
Old Nov 26, 2014 | 08:09 PM
tommoran2's Avatar
Thanks
Looks like a pretty big job.
I may have to just live with the rattle
Old Nov 26, 2014 | 08:54 PM
If you jack up the car and safely support the car with jack stands, you can take a look to see if the three bolts that hold the shield are accessible without removing anything else.
6-point sockets have less chance of rounding the bolt head compared to 12-point sockets. Swivel sockets or swivel adapters or crows-feet wrenches might do the job if there is some space.
Old Nov 26, 2014 | 09:15 PM
Another option that may work, is if you use a metal tightening/mounting strap around the old heat shield to try to stop it from rattling.
reeti
Dec 30, 2008 12:10 PM
Drpepper
May 23, 2007 10:03 AM
hmrnmky
Feb 19, 2007 08:16 PM
Accord98Retro
Sep 7, 2006 03:57 AM
PIGGEBANK
Aug 14, 2006 01:52 AM
