Need Advice: Multiple issues
Hi All
I own a '97 accord EX 4 cyn with 170k miles. Had her since new. She has multiple issues and looking for advice on with items to tackle first and the effort/cost savings of doing the repairs myself.
Thanks
Ray
- The steering track boots are torn. Can I replace the boots or should I replace the whole rack? Can that be done using jack stands?
- The rear motor mount is torn. A lot of vibration around 1500 rpms.
- My oil pressure light blinks sporadically. Changed oil but still blinks. Idles close to zero rpms. Engine does not knock.
Thanks
Ray
Pretty much any engine/car combination you choose to look at will have the oil pressure light blinking if the engine is idling near zero RPMs. I'm thinking if you fix the idle issue, the oil pressure light will take care of itself.
Steering rack boots can be replaced, however tierod outer end must be removed to allow boot to slide over tie-rod threaded end. Yes, it can be done on jack stands.
The rear motor mount can be replaced, but is challenging. See video on youtube
Agree w/ Shipo that very low idle may cause oil pressure light. If light never comes on above idle, this is likely problem. However, the oil pressure switch near the oil filter is also a common failure item and could be the problem. Fix the low idle first (clean IACV and throttle body thoroughly).
The light comes after driving for about an hour.
Symptoms suggest either intermittent faulty oil pressure switch or low oil pressure.
Suggest changing the oil pressure switch. It is inexpensive and easy to replace. Faster than attempting an oil pressure test w/ a gauge. Job does require elevation of front end on jack stands or front end ramps to access the switch. I believe a large diameter special socket (autozone, etc) is necessary to remove/install the switch.
If oil pressure light comes on after swapping the switch, it will be necessary to determine what is cause of low oil pressure.
Not too long ago, there was a case where faulty oil filter pressure relief valve malfunctioned causing low oil pressure.
Pjw73nh
Jul 18, 2013 12:59 AM
