need camber help!!
Old May 26, 2011 | 12:03 PM
Bw0nz1ca's Avatar
Default need camber help!!
Okay so I've got a 95 accord with a f22b1 MT and i had my alignment checked and my camber is waaayyy out, same with my toe, i work at a dealership and just keep putting on used tires. But im going through a pair of tires every week or so. And i do have a crack in the subframe which is by the lower Rf control arm . Its around 3 inches or so long maybe 2mm wide open. Someone help me out!! Ha what should i do about the camber and subframe??
Old May 26, 2011 | 12:22 PM
A good body shop could repair the crack and restore alignment.
If you want to DIY, I would suggest stop-drilling the ends of the crack and welding a bridge plate over the crack to prevent any further crack extension.
Camber fix will require installation of a camber kit on the upper arms to allow camber adjustment.
Toe-in adjustment is possible using the tie-rod adjustments to return steering wheel to neutral and restore toe-in alignment.
Once you have camber kit installed, aAlignment is best done by a shop w/ alignment tools.
Old May 26, 2011 | 09:55 PM
Tek310's Avatar
added question. where can i purchase a camber kit for UCA's?
Old Jun 4, 2011 | 07:47 PM
ebay, amazon has dozens of options.
19Accord97
Feb 3, 2009 05:42 PM
thunder_x
May 14, 2006 03:10 PM
19accord95
Feb 11, 2006 02:06 AM
