Need help on a 94 Accord 5speed
Old Mar 16, 2011 | 01:43 AM
mpklkj's Avatar
Default Need help on a 94 Accord 5speed
I drained all tranny fluid and oil.
I need to know excatly how to take the trasmission out and put a new clutch in it.
I would really appriciate it.
Old Mar 16, 2011 | 02:10 AM
That is a pretty tall order. I never did that on my 95, so I can't give you detailed instructions.
I would arm myself with as much information as possible.
You can download a 94 shop manual from the online manuals thread in the DIY section. Use the honda-tech link on that page.
There was a recent video from ericthecarguy that covers 90s integras and civics. This is a video that he sells and costs ~$10. Its not for an accord, so you can't follow it exactly. You should get a good idea of what needs to be done along with the shop manual instructions on how to remove the transmission. Just google the term below to get an overview of the video.
1lrhLXhdP4o
Old Mar 16, 2011 | 12:19 PM
mpklkj's Avatar
ok cool. i'll look.. its just difficult haha
I think i would just need to unbolt the tranny right?
Old Mar 16, 2011 | 07:46 PM
JMH's Avatar
JMH
I just did the clutch on my 93 Accord, there alot more to it than a few bolts on the tranny!!! I used a Haynes manual for most of it along with several internet searches for additional detail on stubborn steps. Not sure how long it took cause i worked on it and several suspension items intermittantly over a 2 week timeframe. Its a fairly big job for the inexperienced person (me), but doable if your stubborn and have another ride to use.
Old Mar 16, 2011 | 10:02 PM
draker's Avatar
You are going to need to change our the clutch, pressure plate, resurface or replace the flywheel, replace the throw our bearing, grease the pivot ball, and replace the pilot bushing. Would also recommend doing the rear main seal while you are in there.
If you don't know what this stuff is, I would recommend doing a ton or reading before you dive in. It's a big job. A shop would estimate it to be right around 8.3 hours for everything I mentioned.
As for the procedure.. Get the shop manual as mentioned.
Old Mar 16, 2011 | 10:49 PM
mpklkj's Avatar
alright will try to get the manual.. does anyone have a diagram they can upload or something
Old Mar 17, 2011 | 10:56 AM
Like PA said, look in the DIY section for a thread about manuals. Find one in the 94-95-ish range. That's a lot better than any of the parts pictures that I can post. You'll want the PROCEDURE not just the pictures.
The absolute best manual is published by Helm (www dot helminc dot com). Pricey, but worth it especially if you're gonna do some larger jobs. Like removing the transmission...
stl 96 accord
Jan 31, 2013 12:58 PM
jroxz44
Nov 21, 2012 02:11 PM
bboyalex
Jul 22, 2007 01:47 PM
kwp1229
Sep 22, 2005 04:57 PM
