Need help....about Thermostat
Old Jul 16, 2007 | 11:51 AM
smaglik's Avatar
Default RE: Need help....about Thermostat
there are a few pdf version of actual honda service manuals floating around on here...might find one with a search...or get lucky and someone will post it in here...i cant help you.
Old Jul 16, 2007 | 11:52 AM
You need to download a 94-97 Honda Manual from hondahookup.com for help on this issue. I removed this part to remove my intake manifold during a head gasket replacement. I don't remember having any problems. You should replace the large oring seal to the transfer pipe your damaged part connects into. You will need to remove intake duct for access. Take your time and keep up w/ parts and you'll be fine.
Old Jul 16, 2007 | 11:59 AM
smaglik's Avatar
there you go!
Old Jul 16, 2007 | 03:29 PM
You mean the thermostat case (#8) is cracked?
It bolts to the back side of the engine, and you can see how the water pipe goes into the case. Have new gaskets, including a new O-ring (#26) for that tube.
Old Jul 16, 2007 | 03:55 PM
kennilope's Avatar
yes.. that case where i bolt on the thermostat housing screw is broken.. the bottom one...
how do i replace that..
does it take alot of work?????
so it go to the water pump????
Old Jul 16, 2007 | 04:14 PM
sir_nasty's Avatar
Okay I don't want to confuse anyone but if it's #8 that's broken you just need to purchase a new one and replacement is fairly simple, if it's #6 which is the actual housing that covers the thermostat (not the piece that the thermostat sits in) then that's a simple straight forward repair, if you've got a bolt in there then I would assume that the threading and such on #8 where the bolt goes into is fine and it's the external thermostat housing that's busted...Am I backwards?
Old Jul 16, 2007 | 04:29 PM
  #17
smaglik's Avatar
not the water pump. that looks to be assembly 1 in the pic. the tube that goes from the pump to the thermostat housing.
Old Jul 16, 2007 | 06:15 PM
  #18
kennilope's Avatar
It is number 8 on the drawing the hole at the bottom that hold the thermolstat housing which is number 6.
here is the picture of it.
anybody know how to replace number 8?
step by step would be great.
Old Jul 16, 2007 | 07:22 PM
  #19
Ok, if the threaded hole in #8 is broken (and not the bolt), buy #8, two #12, #25 and #26 from a dealer or website like hondapartsdeals.com.
Unscrew the two bolts (#32) that hold that #8 to the engine. Twist #8 off of the water pipe #11. Installation is the reverse of that order.
Old Jul 16, 2007 | 10:09 PM
  #20
smaglik's Avatar
ORIGINAL: kennilope
haha...excellent use of microsoft paint.
