Need help....about Thermostat
Old Jul 16, 2007 | 11:12 PM
  #21
Default RE: Need help....about Thermostat
Number 12 is the bleeder screw, there's only one of them. You can probably use the old one, but it should be cheap anyway.
There's a couple small hose nipples on that part. If the small hoses are old, you may have to cut them off & buy new.
Otherwise it's just bolted to the engine. On my '98 it's not real easy to get to, so you may want to remove stuff that's in your way. Intake duct, throttle body, heater hoses, ???
Old Jul 17, 2007 | 01:33 AM
  #22
kennilope's Avatar
Thank you guys... will give it a try.. hope i dont' break anything else..
and smaglikyes microsoft paint... fastest easiest way to draw....
a picture worth a thousand words..........
Old Jul 17, 2007 | 10:25 AM
  #23
I've had another thought...
Just in case you disturb the seal at the OTHER end of the pipe, you may want to have 2 copies ofseal #26. With age and heat, that other seal is probably hardened and a tiny bit of movement might cause it to start leaking.
Has anyone ever done this? I haven't. I don't know whether you'll need to unbolt that pipe from the engine & move it when you remove the thermostat case.
Old Jul 17, 2007 | 02:12 PM
  #24
That pipe doesn't need to be unbolted. It is sealed by the oring that sits in a groove. You just need to twist #8 back and forth a bit to get the housing off of there.
hondaisreal
Nov 27, 2012 07:14 PM
ksh571
Nov 22, 2011 07:02 PM
madeline.meamber
Jun 30, 2011 08:48 PM
troy331
Sep 8, 2007 03:20 PM
94accordprobs
Apr 29, 2005 12:11 AM
