Need help diagnosing tach and speedometer problem
Old Mar 13, 2007 | 04:43 PM
james.walters
Default Need help diagnosing tach and speedometer problem
1998 Honda Accord LE
VTEC V-6
4-speed automatic
179,000 miles
Recently replaced the AC compressor which required removal of the alternator. In my apparent haste to finish the job I only hand tightened the positive connection to the alternator (my bad[&o]). Over the course of a week the connection loosened until the car would not start as there was not enough charge in the battery – no indication of any problems up to this point. After several hours the battery refreshed enough to start the car at which point I drove it to the local auto parts store for a recharge.
During the drive, to the best of my recollection, all of the indicators on the dash were lit, e.g. door open sensors. I can’t recall if the tach and speedometer were working or not but I think I would have noticed if they were not. After the battery was charged and the nut on the back of the alternator tightened all seems to be well except the speedometer and tach are both dead. The tach does, however, jump up to the “0” line when the power is turned on (prior to starting the engine). The tech who removed the battery from the car did struggle a bit with the battery harness removal.
I’ve checked the connections around the battery and all appear to be intact. I’ve also visually inspected the fuses. Any suggestion greatly appreciated! Jim
Sobel
Aug 13, 2012 10:04 AM
sschnei
Jun 21, 2012 08:40 PM
lvs4rock
Oct 28, 2010 01:46 AM
razcob
Dec 30, 2007 10:44 AM
sdemasi
Oct 22, 2006 11:29 PM
