Need Help with P1457 code
Old Dec 13, 2007 | 07:36 AM
ajluu's Avatar
Default Need Help with P1457 code
I went to autozone and check the check engine light. It said its a P1457 code. It said possible loose gas cap, purge seniold sensor. Does anyone has the same issue that knows how to fix? I searched this forum and people are saying different things. Thanks
Old Dec 13, 2007 | 10:12 AM
deserthonda's Avatar
Default RE: Need Help with P1457 code
the only things that i have personaly go bad are
the evap 2 way valve and the evap bypass solenopid valve
Both located at rear of car by the fuel tank.driver side area,
Old Dec 13, 2007 | 06:46 PM
HondatechAV6's Avatar
yeah, cvs is common in the salt belt states.
the pcs is rare, but i've had a few on 98s.
Old Dec 14, 2007 | 07:45 AM
ajluu's Avatar
what is the CVS? Do I replace the EVAP canister or the tubes/valves in the EVAP. THanks
Old Dec 14, 2007 | 07:47 AM
ajluu's Avatar
UPdate. I bought a new Gas Cap and reset the check engine light. I drove for days and the light cam on with the same code.
Old Dec 14, 2007 | 06:31 PM
gas cap has nothing to do with that code though. you need to manually energize each evap solenoid and verify they are clicking. if one is not clicking replace it and cross yoru fingers. if all are clicking you need to start vacuum testing(urgh...)
Old Jan 3, 2008 | 12:51 PM
ajluu's Avatar
Just an update. I replaced the EVAP control canister on my 98 and the CEL did not go on for 3 weeks now. Thanks to the forum and the Honda Service Bulletin I found on this forum.
Yessy Consuegra
Jan 18, 2014 08:21 PM
Niteshade
Jul 25, 2013 09:57 PM
bigant
Oct 13, 2008 05:41 PM
mbarnes1982
Apr 3, 2008 09:37 PM
zoominhuman
Mar 30, 2007 06:55 PM
