need help please
Old Oct 16, 2015 | 02:49 PM
Nalex's Avatar
Default need help please
Hello everyone, I am new here and need help with this issue.
I have an 03 Accord EX 4L. To make a long story short, I was stupid enough to remove the TPS plug while the engine was running then I clicked it in back immediately. I went into the car and I couldn't get it out of park, turn it on and off no help unless I use the key to unlock the sifter. I thought it s because I messed around with the TPS and sure enough if I pull the TPS out I can get it out of park. Also the transmission started to act funny. I thought maybe the throttle position sensor went bad and sending wrong feedback to the transmission so I got a multimeter and checked the TPS and I am getting 0.51 at idle and 4.5 at full open throttle which is in the normal range I think. The CEL only turns on when the TSP is unplugged and it turns off when I disconnect and reconnect the battery. The car still idle fine, but I can tell that the transmission is not getting the right signal from the throttle.
I also tried the re-learn procedure with no help.
Any help would be greatly appreciated
I had no problems with the car before this and it was running and shifting smoothly
Old Oct 18, 2015 | 12:06 PM
keep_hope_alive's Avatar
how long are you leaving the battery disconnected? is a door open to allow the dome light to drain any stored energy?
inspect the connector, maybe a pin got damaged or pulled out when you were messing with it.
Old Oct 18, 2015 | 11:29 PM
Do your brake lights work?
Old Oct 20, 2015 | 10:44 PM
Nalex's Avatar
Connector is fine. How long should I keep the battery disconnected?
Nalex's Avatar
Yes they do.
99accordf23a5
May 6, 2014 12:51 AM
esan805
Mar 29, 2012 02:33 PM
Artnmotion
Oct 20, 2008 12:44 PM
Brendo613
Feb 23, 2006 07:26 PM
ryan ortego
May 19, 2005 06:06 PM
