need help temp guage not reading correctly
Old Oct 28, 2012 | 12:28 PM
yosoymi787's Avatar
Unhappy need help temp guage not reading correctly
Ok where to start I have a 1997 Accord 2.2l LX AT that was in a accident and sat for a while but I am fixing it back up and have encountered a problem I cannot get past. I have replaced the radiator, all the houses, belts, fluids, and sensors. The problem being the coolant temperature sensor for the gauge. It has been replaced twice because I thought the first one was faulty, turns out that wasn't the problem. When it is plugged in and I turn on the car the needle automatically shoots up and says the car is over heating even in just the on position before I start it up all the way. My fans kick on fine but I don't know what else to check or trouble shoot? Help please!
yosoymi787
Old Oct 28, 2012 | 01:03 PM
Sounds like the wire or the sensor is grounded out. Trace the wire on/from the sensor and see if it is grounding on something.
Just know that is that wire is grounded....the gauge is prob toast as well.
Old Oct 28, 2012 | 08:45 PM
There's warnings in the shop manual about grounding that wire while troubleshooting the system. If you ground the wire & allow the gauge to shoot all the way up to the top, you can burn out the gauge. So even after fixing the wire, you still have to deal with a (possibly) burned out gauge.
Old Nov 1, 2012 | 09:11 AM
yosoymi787's Avatar
Thank you for all the info. problem fixed gauge was shot replaced it!!
vikkyhonda
Feb 1, 2012 06:34 PM
jgresh110
Jun 26, 2011 09:41 PM
dadkind
Apr 25, 2011 06:33 PM
dre2430
Apr 21, 2011 11:01 PM
pryan26
Mar 8, 2007 08:19 PM
