need help with trouble code 94 accord
Old Oct 19, 2012 | 05:33 PM
1994 accord's Avatar
Default need help with trouble code 94 accord
I just checked the code that was making my check engine light come on and it is showing code 95. Problem is, I just cant find anything saying what this code is. If anyone could help, it would be greatly appreciated.
Old Oct 19, 2012 | 09:22 PM
Dr. Drivability's Avatar
there is a code 9 for the MIL, CYP sensor circuit problem (cyl position sensor), code 5 is related to either the trans control system or the abs system, not anything to do with the MIL coming on. so no, no specific code "95"
Old Oct 27, 2012 | 05:33 PM
Ok, i figured out the actual codes now. They are codes 9, and 41.
Old Oct 28, 2012 | 10:34 AM
41 is the oxygen sensor heater circuit.
Old Oct 28, 2012 | 10:51 AM
9 is for cylinder #1 position sensor, these are usually a pain to figure out.
Old Oct 28, 2012 | 12:08 PM
For code 9, check sensor resistance against spec (700-1300 ohms for vtec engine and 350-700 ohms for non-vtec).
First check resistance at the distributor connector using pin arrangement from shop manual to locate sensor pins (4-8).
If w/i spec, check resistance again at the ECM connector B (pins B11 & B12). If w/i spec again, the ECM is faulty and will need replacement.
If you don't have a shop manual see DIY forum post Online Manuals for download manual.
Code 41 usually means O2 sensor fault. If sensor is over 60K miles old, get a new one (denso is a good buy, check ebay, amazon, or rockauto).
arvil
Jan 28, 2012 06:46 PM
joeyduguay
Sep 27, 2011 03:58 AM
22R
Dec 12, 2008 06:28 PM
jbone
May 12, 2008 06:54 PM
Brendo613
Feb 23, 2006 07:26 PM
