Trouble code 9 Accord EX 2.2L AT wagon
Old Jan 28, 2012 | 02:07 PM
arvil's Avatar
Default Trouble code 9 Accord EX 2.2L AT wagon
New Distributor. reset codes still come up 9. Hard to start and accelerate initially. Do I need to change out the ECM?
Old Jan 28, 2012 | 02:13 PM
Is code 9 being flashed by the check engine light or the D4 light?
What year is your accord?
Old Jan 28, 2012 | 02:53 PM
arvil's Avatar
check engine light - 9 blinks
accord EX 2.2L AT wagon
Old Jan 28, 2012 | 02:57 PM
arvil's Avatar
sorry 1994
Old Jan 28, 2012 | 06:46 PM
In the common DIY thread on top of the gen tech help forum, there is a link to online shop manuals. The honda-tech site has a 94 accord manual that you can download.
If you have a volt meter, test the resistance of the sensor at the electrical connector at the distributor across the proper pins. See if it is within specs. Then test the same pins where they plug into the ECU. If the resistance is the same, then a faulty ECU is likely.
I believe TexasHonda (a moderator on here) had a thread about the same problem.
Here is the threa:
https://www.hondaaccordforum.com/for...ode-9-a-36090/
daver1100
May 8, 2014 02:41 PM
4mfrance
Apr 28, 2012 08:07 PM
arvil
Jan 28, 2012 12:47 PM
joeyduguay
Sep 27, 2011 03:58 AM
22R
Dec 12, 2008 06:28 PM
