need how to on replacing cv axle 94 accord
Old Apr 19, 2012 | 11:00 PM
R.Weed93's Avatar
Default need how to on replacing cv axle 94 accord
Hi guys, I just purchased a 94 Accord 141k miles 5 speed f22b1 motor. But anyways it has bad cv axle also describe as by the guy as a cv joint didn't say how it happened or when but when I went for a test drive there wasnt any shakin or vibrating of any sorts even up at higher speeds (up to 55mph) didnt want to over do it and go on the highway. but anyways im gonna go ahead and replace it and i need help like a step by step how to on replacement thank you!
Old Apr 19, 2012 | 11:22 PM
When a CV joint goes bad, there is usually a clicking sound when you make a turn.
Take a look at the outer boot to see if it is torn. There will be grease everywhere.
There is a good video on YouTube. Just search ericthecarguy cv joint to how to replace.
TexasHonda is another moderator on here and mentioned that raxles make good CV joints. Some of the remanufactured ones can cause the car to vibrate or may fail prematurely. They will be more expensive than the remanufactured ones though.
Old Apr 20, 2012 | 12:48 AM
deserthonda's Avatar
Old Apr 20, 2012 | 03:04 AM
my1st.honda93's Avatar
R.weed93 there are in fact 3 obvious signs to tell if ur axle is bad,1-look to see if ur cv boot is torn as PAhonda mentioned,2-the clicking sound u hear as u make a turn,3-while u r driving u will hear a deep humming sound coming from the front end an will get a bit louder the faster u drive.those are 3 tall tail signs that ur axle is bad,an if u find out ur axle is bad an u will replace it urself do urself a favor an go to autozone spend $25 an buy the Haynes Repair Manual for ur car it will give u step by step instructions on how to do what ever it may be that u need to do on ur car,looking at a video is ok for some people but me personally id rather read to get the knowledge!get the manual you'll thank me later.lol good luck!
Old Apr 20, 2012 | 03:03 PM
Step 3 in the previous post would point more towards a bad wheel bearing.
Getting shop manual is a good idea. Open the common diy thread on top of the gen tech help forum, then open the link to online shop manuals. That thread has links to sites that have a 94 Honda shop manual that you can download as a pdf.
lotusbomber
Nov 8, 2014 11:27 AM
gfam
Apr 19, 2012 08:48 AM
l Ottesen07 l
Oct 6, 2009 03:20 AM
sunny393
Dec 17, 2007 01:46 PM
nixalot
Jan 25, 2007 02:02 PM
