Need hub assembly help
Old Oct 15, 2018 | 06:26 PM
kpodschweit93's Avatar
Default Need hub assembly help
Trying to do front hub assembly and wheel bearings on my 95 Honda Accord lx 2.2L Got every taken off but managed to completely strip one of the bolts in the back side of the rotor. Ended up have to cut the head off the bolt to get it out and now need to get new bolts but not sure what the specs or the name of them is. Please help this girl trying to fix her own car.
Old Oct 15, 2018 | 06:34 PM
Old Oct 15, 2018 | 06:39 PM
Seanjordan20's Avatar
This is the bolt you are looking for. It's a 10x40
P/n: 90164-SM4-013
If you are talking about the stud then just go to Advance and get one. I'm pretty sure they will have the hub bolt also
Old Oct 15, 2018 | 06:43 PM
Default Thank you
Thank you so much. I went to Napa and a few hardware stores trying to find it since that's where my mechanic friend had told me I could find it but had no luck. Are these bolts like a Honda specific thing?
Old Oct 15, 2018 | 06:46 PM
They are but the thread is what you would pay attention for. If you have a fastenal they should have something to fit it
Old Oct 16, 2018 | 06:17 AM
Since they hold the wheel bearing in place, you need the strength not just the size. Fastenal will have all kinds of bolts that will fit but not necessarily strong enough. Unless you actually tell them what it's for and/or bring the old one along.
The "new member" area is mostly for welcome & introductions. I'll move this over to General Tech where more people will see it.
Old Oct 16, 2018 | 04:54 PM
Eran Teitelbaum's Avatar
why not buy it from a honda dealer?
Old Oct 17, 2018 | 06:05 AM
Local auto-parts stores might have wheel studs, but probably not the hub/bearing bolt.
Yes, a Honda dealer would be the best place to get it; & I bet they're not stupidly expensive at a dealer either.
Old Oct 17, 2018 | 06:37 AM
If I'm looking for a bolt I would definitely bring one so I can compare and ask questions. Auto parts carry all sorts of bolts for different things, meaning not necessarily marked for your application. Many times I've went into advance, went to the back and found something that will work. If you don't go to the back you of course will not find what you are looking for.
The type of bolt you use is important and it is best to just go to the dealership then you will know you have the exact item you need but I assure you one odd bolt out of four will not have your assembly falling off. If that happens you have another issue and maybe you don't need to be doing your own work.
Old Oct 17, 2018 | 09:41 AM
It’s 4 bucks at clark knapp, i bought many things there and they arrive as far as israel.
joenintiesc
Apr 14, 2013 07:29 AM
ryandamartini
Aug 15, 2011 09:18 PM
rykertest
Jun 4, 2010 01:05 PM
jeff2425
Mar 9, 2010 10:55 AM
brownstreak
Jul 3, 2006 06:38 PM
