Need some help
Old Jun 17, 2010 | 10:17 PM
blake's Avatar
alright well now the car wont even start, i have both spark and fuel
sometimes you turn the key to start it, the dash lights come on, the fuel pump comes on, but it will do nothing, not even crank
other times, it will crank and try to turn over (makes a "put put" sound) but still wont start.
with all my other guage issues and electrical issues, could this be possibly a faulty ignition switch? i read that they can mess up electrical systems in cars and etc.
Old Jun 18, 2010 | 01:23 PM
blake's Avatar
so it has good fuel pressure, good spark, timing belt isnt broken
when you turn it over the car tries to start (makes a "put put put" noise) and sometimes even backfires
the spark looked good, how can you tell a good spark from a weak spark?
what else would keep it from starting? im stumped
Old Jun 19, 2010 | 12:07 PM
Take the air-intake duct off the throttlebody. Spray starter-fluid in there while someone tries to start. If it "starts" strong for a couple seconds before stalling again, that indicates a good spart.
Spark should be bright & blue/white. Yellow is weak. If you have a timing light, that generally won't light up consistently with a weak spark.
Old Jun 22, 2010 | 10:10 AM
blake's Avatar
thanks for the help guys
turns out my timing belt skipped a few teeth
lets hope the valves arent bent
Old Jun 22, 2010 | 05:30 PM
Ouch. Yeah, hope the valves aren't bent.
Brian
Jul 17, 2006 10:31 PM
19accord92
Apr 15, 2006 08:50 PM
HondaLawgik
Feb 8, 2006 02:21 PM
blazedg
Jul 5, 2005 07:52 PM
blacktopracer
May 11, 2005 10:11 PM
