Need vacuum diagram P1491 problem
Old Jan 13, 2011 | 09:18 AM
Did you find instructions for base idle?
After you unplug the IACV you don't just plug it back in. Let it cool down, reset ECU, & force it to re-learn the idle.
Old Jan 15, 2011 | 03:30 PM
Racemaster's Avatar
Default IACV relearn
I must have missed that part somewhere.
So, unplug it while running, idle the engine down to base idle at 550rpm. Turn it off, let the engine cool, remove battery cable or use scanner to clear codes, plug the IACV back in and start it up so it will relearn idle?
Does that sound correct?
If there is a link for it please post it. Thanks
Old Jan 15, 2011 | 06:41 PM
Its in the DIY section, but I should've just typed in more complete instructions...
After you adjust the base idle:
- turn it off, let it cool down completely, plug everything back in, reset ECU.
- start the engine without touching the gas pedal.
- let it warm up completely without touching the gas pedal.
Bange
Jun 25, 2014 05:43 PM
jfidelh
Aug 18, 2011 08:55 PM
dhalla196@rogers.com
Mar 7, 2007 09:21 PM
BertMan
Jan 30, 2007 02:15 AM
2001 Accord VTEC
May 19, 2006 07:29 PM
