Need window help for 91 accord
Old Jun 17, 2005 | 04:05 AM
s x t x a x r x z
Default Need window help for 91 accord
I just got a 91 accord and I was checking that everything worked like the lady said it did. Sure enough the drivers side back seat window is messed up. I guess its something with the window motor because it went all the way down but wont go up at all. I tried with a napkin and pliers to pull it back up but no luck. Any suggestions?
Old Jun 17, 2005 | 01:03 PM
tgriffin27
Default RE: Need window help for 91 accord
Your window motor may be bad but since it worked going down I am going to say that the regulator may be bad. Pull the door panel off and see if the regulator looks okay no loose wires hanging out of it. Take the ground wire off the battery and take the motor off the regulator should be a few nuts holding it to the regulator. When you have the motor off reattach the battery cable to the battery so you can test the motor to see if works up and down. If it works you have a bad regulator.
Old Jun 20, 2005 | 03:28 AM
Congradulations Tgriffin27 you get the $1.00 cigar for the bestest correct answer on the window problem, in other words ( correcto mondo )..
ORIGINAL: tgriffin27
Old Jun 21, 2005 | 08:16 PM
Evlampius's Avatar
$1.00 cigar?? thats it??
Old Jun 22, 2005 | 03:13 AM
They dont give us an allowence here in the forums, cigar is all we can get him...
Now, where to send it???
Old Jun 24, 2005 | 08:33 PM
Shocker's Avatar
wheres my cigar? lol
jkeely
May 2, 2012 03:48 PM
ravenr106
Oct 21, 2011 06:08 AM
ravenr106
Oct 20, 2011 05:32 PM
2006accordexl-passmirrorbroken
Apr 12, 2010 03:01 PM
mmazb3
Nov 26, 2007 03:16 PM
