New to the Honda
Old Aug 5, 2008 | 11:23 PM
Revgross96
Default New to the Honda
Hello everyone,
I am new to the Honda Accord as this 91 is my first try at a honda. I hope someone can help me out. My speedometer comes and goes for no apparent reason. Also there is a green S flashing on the dash and I have no idea what it means.
Thanks,
Old Aug 6, 2008 | 08:23 AM
Default RE: New to the Honda
Maybe your VSS? That would explain both. Read the error codes from your TCU.
https://www.hondaaccordforum.com/Sti..._128656/tm.htm
Old Aug 6, 2008 | 05:38 PM
Revgross96
Not sure what the terms mean can you elobrate.
Thanks
Old Aug 6, 2008 | 07:38 PM
http://www.dhost.info/accordinfo/howto/cel.html Gives instructions that are pretty similar to your accord. Your plug is brown. Short that connector with a thin paper clip.
Instead of counting the Check Engine Light flashes, you count the S flashes. I will bet that your S light will flash 4 times (bad VSS) and that the Check Engine Light will flash a code 17 (also a bad VSS).
Old Aug 6, 2008 | 07:46 PM
Took me 10 tries to post that already...
VSS = vehicle speed sensor
Thats on the tranny instead of a speedometer cable.
TCU = tranny control unit (computer)
Old Aug 7, 2008 | 06:02 PM
Revgross96
Ok great info so far. I found this test ( http://autorepair.about.com/library/faqs/bl112f.htm)
do you all think it iscorrect for my 91.
Also I will check the link from PAhonda when I get home. Icant see it from work.
Again Thanks,
Old Aug 7, 2008 | 10:35 PM
Revgross96
HA PAhonda the link you left for me keeps saying error 404. any other ones you know of would be great.
Old Aug 7, 2008 | 10:39 PM
Revgross96
Also the green S light flashes constantly no breaks at all.
Old Aug 7, 2008 | 11:08 PM
91 is old style blinking LED on ECU itself.
http://www.troublecodes.net/honda/
The link you found in post #6 is probably good, but wire colors might be different.
JamesWLee0531
Feb 19, 2017 02:29 PM
2010couper
Jul 8, 2010 05:11 PM
Bjonesffxi
Jan 12, 2009 06:58 AM
giffink
Aug 31, 2007 08:58 AM
giffink
Aug 30, 2007 10:16 PM
