New to the Honda
Hello everyone,
I am new to the Honda Accord as this 91 is my first try at a honda. I hope someone can help me out. My speedometer comes and goes for no apparent reason. Also there is a green S flashing on the dash and I have no idea what it means.
Thanks,
Thanks,
Maybe your VSS? That would explain both. Read the error codes from your TCU.
https://www.hondaaccordforum.com/Sti..._128656/tm.htm
http://www.dhost.info/accordinfo/howto/cel.html Gives instructions that are pretty similar to your accord. Your plug is brown. Short that connector with a thin paper clip.
Instead of counting the Check Engine Light flashes, you count the S flashes. I will bet that your S light will flash 4 times (bad VSS) and that the Check Engine Light will flash a code 17 (also a bad VSS).
Ok great info so far. I found this test ( http://autorepair.about.com/library/faqs/bl112f.htm)
do you all think it iscorrect for my 91.
Also I will check the link from PAhonda when I get home. Icant see it from work.
Again Thanks,
Again Thanks,
91 is old style blinking LED on ECU itself.
http://www.troublecodes.net/honda/
The link you found in post #6 is probably good, but wire colors might be different.
JamesWLee0531
Feb 19, 2017 02:29 PM
