new leak
Old Oct 2, 2010 | 05:29 PM
drummer1279's Avatar
Default new leak
ok, so I didn't do anything major. removed my valve cover and upper timing cover to just give a check on things before driving to Orlando coming up. put everything back together, now I have what sounds like an air leak and I'm pouring oil, no moisture or anything to suggest its the valve cover or the timing cover mis installed.
Old Oct 2, 2010 | 09:38 PM
Did you replace the PCV system from valve cover to throttle body?
Old Oct 2, 2010 | 09:54 PM
no, I didn't replace anything, I had no intention of doing so. The sole purpose was to check the condition of my timing belt. the valve cover gasket and tube seals, and the PCV valve are barely 3 months old.
Old Oct 3, 2010 | 12:02 AM
kris_loehr's Avatar
Any chance you have something caught under the valve cover like a vacuum line or do you no oil leak only consumption of oil.
Johnene
Aug 24, 2010 06:59 AM
v-tec23
Aug 14, 2010 08:43 AM
EBK142
Jul 20, 2009 09:10 AM
96hondaaccord
Dec 16, 2007 04:16 PM
xaznxeclipsex
Sep 28, 2007 02:05 PM
