New member with transmission questions
Old Dec 5, 2012 | 07:40 AM
Silver6gen's Avatar
First of all I'd suggest adding a transmission cooler
https://www.hondaaccordforum.com/for...ictures-48791/
As far as DIY for the rebuild.... Ehhh you can if you want, but these transmissions are a colossal PITA. If you have the ability to machine then press new bearing guides in to the case then sure go for it. IDK where a service manual is still looking, I'd bet redbull or poorman can point you in the right direction. My bet would be honda is the only one that has it.
Just so you know what you are potentially getting into watch this video
Old Dec 5, 2012 | 12:44 PM
cascius's Avatar
Thanks for the video. Doesn't look terrible by any means. Found the manual so I think I'm going to go ahead and get it coming. It might help give a better idea of what this is going to take. Once I have time to check it over I'll have a better idea of what I plan on doing.
Old Dec 5, 2012 | 12:51 PM
Silver6gen's Avatar
Good Luck, it would be absolutely awesome if you could take pictures while you do this and post them here. A little write up would be helpful too for others who are as ambitious as you.
Old Dec 5, 2012 | 02:01 PM
cascius's Avatar
Will do. I was thinking the same thing on pictures and write up. I'm still looking into this and doing some research to diagnose it as best as possible before I pull it apart. Thanks for all the info so far.
Old Nov 28, 2017 | 01:55 AM
fast eddie's Avatar
Eric the car guy said he thought he had the wrong clutch pack when he took it apart and it looked ok(didn't measure thickness, but visually it looked ok). He didn't say whether he did or did not have the wrong pack...I'm about to tackle this, so I sure wish he woulda been more plain on that...I wonder how cascius did with his attempt???
csorbera
Feb 6, 2011 07:18 PM
dinenasty
Feb 4, 2011 08:52 PM
2006accordexl-passmirrorbroken
Apr 9, 2010 01:05 AM
ACCORDx07xBABY
Feb 19, 2008 05:01 PM
gorilla
Nov 29, 2007 05:43 PM
