New PS system still leaks
Old Feb 16, 2018 | 05:16 PM
'89 Accord LX's Avatar
Default New PS system still leaks
I just replaced my old worn out rack & pinion with a new one and replaced the pump too. I still have a leak somewhere but i can't figure it out. Can anyone help me out?
Old Feb 17, 2018 | 10:28 AM
Wipe down the lines with a rag and look for wet spots. Look closely around the VSS lines.
Old Feb 17, 2018 | 01:05 PM
Alright. I'll do that and try to post an update. Thanks!
Old Feb 17, 2018 | 02:10 PM
So I wiped down the lines and went for a very short drive (just down the road). When i got back i opened the hood and the reservoir had filled back up but it wasn't really that low to start with. I don't know how to explain that
Old Feb 18, 2018 | 06:36 AM
Is the PS fluid "foaming" up, if the system is sucking air in, it can sometimes cause the fluid to foam up ?
Old Feb 18, 2018 | 10:34 AM
It is foaming still. I still cant find any air leaks since i replaced the LP lines from pump to reservoir.
Old Feb 18, 2018 | 10:46 AM
I'm not as familiar with the 89, but remove the connections to the PS pump and check that you didn't tear an o-ring on the lines when you installed the lines.
Old Feb 19, 2018 | 04:57 PM
I've installed o-rings on the lines several times. I went through 5 pumps on my car and the o-rings that came with them always came out without damage. I can bet that i have an air leak at my vss like poorman suggested
nigel
Oct 28, 2012 10:00 AM
johnmcclen
Nov 11, 2011 09:14 AM
xaznxeclipsex
Sep 28, 2007 02:05 PM
longneck8769
Mar 28, 2006 06:19 PM
longneck8769
