New top end vs reman engine
Old Dec 1, 2017 | 07:00 AM
djkurious's Avatar
Keep us updated!
Old Dec 1, 2017 | 12:06 PM
TexomaAccord's Avatar
Hooked up the battery to the starter, hooked up a bump button to spin it over (curious about 1,3,5 compression) and starter just spins. Not engaging.. arrggg
Old Dec 1, 2017 | 03:45 PM
shipo's Avatar
Originally Posted by TexomaAccord
ps.. that engine is SO heavy, it kept trying to tip over my cherry picker -- I had to back my suv up to it and chain it down. But if you notice, I lifted the entire front of the car with the cherry picker with 0 issue, 0 tipping
While it is true I've never even seen a 2.7 liter V6 mill, I was kinda-sorta under the impression both the engine and the transmission were pretty much made of aluminum (i.e. heads, block, tranny case), I cannot figure out how that could be so heavy a cherry picker would have an issue with it. That said, the last time I pulled a motor with a cherry picker was when good-old American iron was used to make V8 engines, so maybe the cherry pickers of that era were more robust.
Old Dec 1, 2017 | 04:32 PM
Will a 95 v6 electrical hook up the same as my 97 v6
Old Dec 1, 2017 | 04:56 PM
I think it was leaking from the distributor
Old Dec 2, 2017 | 10:58 AM
You might run into some problems because a 97 is obd2 and 95 is obd1. Likely the distributor will have different wiring.
But not too many people ever messed with the v6 accords(I know I didn't) so there isn't too much knowledge out there about it.
Old Dec 2, 2017 | 11:07 AM
  #17
Check the OBD-1 thing because I'm not certain. I remember the Accord V-6 being one of the very few cars that complied with OBD-2 a year early.
Old Dec 2, 2017 | 11:38 AM
  #18
Ok so I ran a better compression test, cold and wot
Here are the numbers
1 - 140
3 - 90
5 - 135
​​​​2 - 140
4 - 130
6 - 135
I'm thinking since the newer engine is a 95 , I may just go ahead and do a top end rebuild on mine.( A lot cheaper) Maybe I can get 500k miles out of this car.
Thoughts?
Old Dec 2, 2017 | 03:25 PM
  #19
The 95 V6 was OBD2, so the engine is identical to your 97.
Are those compression numbers above from the 97 or 95 engine?
Old Dec 2, 2017 | 04:19 PM
  #20
The numbers are from my 97
