New top end vs reman engine
Old Dec 5, 2017 | 05:04 PM
  #31
TexomaAccord's Avatar
Cleaned
Fun times
Old Dec 6, 2017 | 07:23 PM
  #32
what do you guys think about that gasket?
Old Dec 9, 2017 | 08:06 AM
  #33
Guessing at the gasket by pictures is hard to tell. I'd have a machine shop check the head, then go from there.
Old Dec 9, 2017 | 11:26 PM
  #34
im gonna check and see if they are warped and how much needs to be taken off.
Old Dec 10, 2017 | 08:34 AM
  #35
I finally decided to drain the oil... Ooooo water in the oil.. Nice..
Now trying to finger out how to get these valve seals out? EDIT --- Chapter 2 Part C - 2c-13 --- EDIT AGAIN -- Haynes says take it to a professional... ARG!!
Also, my injectors look NASTY!! 9v battery, carb cleaner cleaning? Thoughts?
Old Dec 10, 2017 | 08:50 AM
  #36
Are you trying save a few $'s by taking them out? Usually the machine shop will go through all of that when they check it out - if you got a gasket set that has them be sure to take them to the shop when you drop off the head.
I think TX (TexasHonda) did some injector cleaning, might search for a thread/post from him about that (one of the Mod's on here)
Last edited by poorman212; Dec 10, 2017 at 08:56 AM. Reason: full user name not my shorthand :)
Old Dec 10, 2017 | 09:06 AM
  #37
I'm not paying anyone to do anything on this car. Doing it all myself. I have access to a machine shop, but its really a "there's the tools, good luck" type of adventure. -- I also have access to an injector tester, cleaner, science looking machine, but that thing looks complicated. On my explorer, I soaked injectors, rigged up a valve stem to fit over one end of the injector, with a straw hooked to a can of b12 and sprayed and triggered the injector with a 9v battery.
After reading some more, it looks like the valve seals can just pull right up with a little force.
Old Dec 10, 2017 | 09:33 AM
  #38
I will search for his post.
Another question... Is there a way to test the tdc sensor? I'd hate to drop $250+ for one if it was just a bad wire, and I'd hate to put this motor back in (because of tdc location) if it was bad
Old Dec 10, 2017 | 09:50 AM
  #39
Usually there are test spec's for them - resistance and check for continuity to ground, ect. I don't have the spec's for a 5th gen V6
Old Dec 12, 2017 | 01:39 PM
  #40
Pits... jb weld and smooth down?
