New top end vs reman engine
Hmmm, positive displacement oil pumps (virtually every engine oil pump I ever remember seeing) will pump oil even at hand-crank rotational speeds.
so should i hand crank it over a bit before installing and starting it? id like to make sure I have oil in all the little nooks and crannies (where it should be) before I try to start it..
ie.. hydraulic lifters, lashers, all that jazz
If you used good quality assembly lubes and pastes, you should be good to go; if you prefill the oil filter the oil will pump up pretty quickly, typically before the engine actually starts.
