New top end vs reman engine
Old Feb 5, 2018 | 05:29 PM
  #81
TexomaAccord's Avatar
What drives the oil pump? I'd like to prime all the internals with oil
Old Feb 7, 2018 | 10:35 AM
  #82
Im guessing the crank does, and no way I'd be able to spin it fast enough to do so...
anywho.. got my new plug wires in today.. woot
Old Feb 7, 2018 | 11:33 AM
  #83
shipo's Avatar
Hmmm, positive displacement oil pumps (virtually every engine oil pump I ever remember seeing) will pump oil even at hand-crank rotational speeds.
Old Feb 7, 2018 | 11:43 AM
  #84
so should i hand crank it over a bit before installing and starting it? id like to make sure I have oil in all the little nooks and crannies (where it should be) before I try to start it..
ie.. hydraulic lifters, lashers, all that jazz
Old Feb 7, 2018 | 01:11 PM
  #85
shipo's Avatar
If you used good quality assembly lubes and pastes, you should be good to go; if you prefill the oil filter the oil will pump up pretty quickly, typically before the engine actually starts.
Old Feb 7, 2018 | 03:32 PM
  #86
Transmission mount
Old Feb 7, 2018 | 05:17 PM
  #87
shipo's Avatar
Ummm, she's broke. Maybe with some JB Weld you can rebuild it; or not!
Time for a new unit.
Old Feb 7, 2018 | 06:04 PM
  #88
Perhaps running a water hose through it may fix it
Old Feb 8, 2018 | 05:19 PM
  #89
New one on the way, can't wait to get this thing back in the car and have it on the road again.. Inspection is next month
Old Feb 12, 2018 | 07:20 PM
  #90
Looks new and pretty
