New Vss and speedometer doesn't work
When I bought the Accord last year the speedometer would occasionally stop working (so did Cruise control) , and it got worse. Last week the d4 light started flashing and the Check engine light came on. So I did some research and decided on replacing the VSS instead of running codes.
With the new VSS installed the D4 stopped flashing and the check engine light went off. At first the speedo worked fine, a little slow to pick up the speed, but worked. Next day the speedo is not working again, but no lights this time.
Anyone have any pics of the back of a cluster that NEEDED soldering? I think that might be my problem, but would not know what to solder.
Thanks,
jason
Thanks,
jason
Is the odo and trip odo working? If not, sounds like the PCB is bad. There are a few write ups around where people have "touched" up the contacts on the PCB and got it to work.
Others grab a PCB from another car and swap it for the old one - that way you keep the milage on yours....but that is off a bit because it is not working
Ralph
Apr 12, 2012 06:03 PM
cuatro201821
Apr 1, 2008 09:06 AM
