New Vss and speedometer doesn't work
Old Feb 10, 2014 | 12:33 PM
jrock24's Avatar
Default New Vss and speedometer doesn't work
When I bought the Accord last year the speedometer would occasionally stop working (so did Cruise control) , and it got worse. Last week the d4 light started flashing and the Check engine light came on. So I did some research and decided on replacing the VSS instead of running codes.
With the new VSS installed the D4 stopped flashing and the check engine light went off. At first the speedo worked fine, a little slow to pick up the speed, but worked. Next day the speedo is not working again, but no lights this time.
Anyone have any pics of the back of a cluster that NEEDED soldering? I think that might be my problem, but would not know what to solder.
Thanks,
jason
Old Feb 11, 2014 | 10:35 PM
Clear any codes by pulling the 7.5 amp backup/radio fuse in the engine bay fuse box. Then drive until the speedometer messes up. Then check the codes.
Old Feb 12, 2014 | 11:41 AM
jrock24's Avatar
Will that make me put in the radio security code?
I was driving yesterday, no speedo at all but the Cruise control was working.
Old Feb 12, 2014 | 02:56 PM
Cruise control uses the VSS signal, so that means the VSS must have been working OK at the time. Sounds like you have something going on "downstream" from where the cruise-control gets that signal.
Old Feb 15, 2014 | 10:39 AM
Is the odo and trip odo working? If not, sounds like the PCB is bad. There are a few write ups around where people have "touched" up the contacts on the PCB and got it to work.
Others grab a PCB from another car and swap it for the old one - that way you keep the milage on yours....but that is off a bit because it is not working
Old Feb 15, 2014 | 07:10 PM
96FiveSpeed's Avatar
Thats how come so many of these cars havent tipped 200K on the odo yet...for 5 years going,it stays at 165 or 180 K lol.
Old Feb 17, 2014 | 05:46 PM
Had a 95 at 385K, only lost around ~200 miles due to a sticking odo/trip - hitting the manit re-set pretty good with the key fixed that....then one VSS.
Old Feb 19, 2014 | 12:26 PM
jrock24's Avatar
The odometer does not work when the speedometer isn't. I am going to try and find the write up and do the PCB.
Ralph
Apr 12, 2012 06:03 PM
jethro
Nov 5, 2009 11:26 AM
swift8585
Mar 30, 2009 06:55 AM
cuatro201821
Apr 1, 2008 09:06 AM
comptoncarl
Feb 8, 2007 03:04 PM
