newbi
Old Feb 27, 2009 | 09:18 AM
polish85
Unhappy newbi
my gf has had her 96 honda accord for a few yrs now and the window stopped working. she says she has gotten a new window regulator and motor before and that one broke as well. is it a short in the system or do i need to replace something else? she said one of her other friends said that the rubber strip around the window needs to be replaced as well for it 2 work correctly. is this true?
so before i go and buy new window regulators and motors off ebay, do i need to know anything else?
Old Feb 27, 2009 | 09:19 AM
This is an extremely common problem with these cars. Did it stop working all together or does it just go up really slow?
Old Feb 27, 2009 | 09:21 AM
polish85
she said it went up and down slowly at first and then stopped all together
Old Feb 27, 2009 | 09:24 AM
Sounds like the classic issue, I would suggest first lubing up the window tracks to see if that helps it before you spend the $100+ on new motors.
Old Feb 27, 2009 | 09:30 AM
polish85
they havnt worked for about 7 months so i guess i just have to get new motors...thanks
Old Feb 27, 2009 | 08:35 PM
Cool Only to Post In the Correct Forums
Make sure you post where the answers to your questions will be better seen..
Old Mar 5, 2009 | 05:05 PM
Stiffy's Avatar
I just started experiencing the same issue with my front passenger window this morning on my 97 Accord EX sedan. The window rolls up slowly and then stops when it's about 4 inches away from going all the way up. From this point, I have to grab it with my hand to guide it all the way up to get it to fully roll up. Could this be a sign of my window regulator getting ready to go out on me or is it something else? In the meantime, what do I use to lube up the window tracks to see if it helps?
Old Mar 10, 2009 | 09:53 PM
Demonrunner's Avatar
I'm personally gonna try PB Blaster on my 87 Accord to see if my windows work any better... They go real slow (bout half the speed of my wifes 2001 F150) When really cold (below 10 Degrees F) they stop all together.
66caprice
Feb 27, 2015 07:42 PM
mikes
Oct 23, 2005 10:34 PM
