Newbie: 98 accord ex 4cyl - misfire - HELP
Old Sep 19, 2011 | 11:35 AM
dsm2925's Avatar
Default Newbie: 98 accord ex 4cyl - misfire - HELP
i did a little tune-up.
i replaced sparkplugs, wires and distrubtor, fuel filter, air filter .
check engine light on with misfire and i went to autozone for a dianose and they said egr valve.
change egr valve and still same.
i have look for answers on this forum but dont have anwsers
Old Sep 19, 2011 | 11:45 AM
What code/s were reported? Be specific.
Was code P0401 set? Was random misfire code P0300 reported?
EGR problems are usually not the EGR valve fault, but rather blockages in the path/s from EGR valve to intake manifold. Please check DIY Forum for a DIY for your generation Accord. I think you need to remove throttle body to access port for cleaning.
Old Sep 20, 2011 | 07:59 AM
dsm2925's Avatar
i got to double check the coded again. by the way on high rpm or on the highway the car is ok.
Old Sep 20, 2011 | 08:13 AM
dsm2925's Avatar
a friend told me possible one of the cylinder valves are damaged or chiped and causing leak
Old Sep 20, 2011 | 04:03 PM
Post the actual code on here before assuming anything.
Old Sep 21, 2011 | 05:05 PM
dsm2925's Avatar
I got p0300 & p1399
Old Sep 21, 2011 | 05:59 PM
Those are both misfire codes.
Did you replace the entire distributor? If so, why?
What spark plugs did you use?
JokerJay
Sep 17, 2013 10:32 AM
hondamxracer
Dec 4, 2011 05:27 PM
on1accord
Nov 24, 2010 09:01 PM
zaqan
Nov 13, 2010 02:06 AM
