No brake fluid!? Help
Old Sep 21, 2012 | 07:22 AM
Samzebian's Avatar
A bone yard caliper will work, just for how ling is the question......10 years, 10 days?
As far as the fluid, well there isn't a "spec" for the amount, that I see. With 2 qts you should be fine. If you are going to flush/bleed them. Do yourself a favor, suck the old fluid out of the brake master before you start, many methods on how to do this. Fill the master with fresh fluid and have fun. I bleed brake with "Newton", takes a while but does work.
Be sure to follow the proper sequence for the bleeding.
well I had my buddy help me and brakes are stronger than ever! Thanks everyone! Btw I only needed the one bottle so I'm returning the unused one. I didn't even need to flush the entire system out, just pump and pump until a good solid stream of it came out, not much air got in the system after all, I guess I caught it early.
IF YOU WOULD LIKE, you could also help me with my engine check light on this post! Thanks guys!
93Accord2.2
Dec 17, 2021 09:59 AM
62maxx
Oct 18, 2015 08:20 AM
nyaccodguy
Mar 17, 2015 06:38 PM
redman4ever
Jan 31, 2011 04:23 PM
19962door
May 17, 2010 03:30 PM
