no compression
Old Jan 8, 2013 | 01:05 PM
  #21
greasemonkey's Avatar
Is it better to pull engine/trans out together or leave trans in car?
Old Jan 8, 2013 | 09:11 PM
  #22
shipo's Avatar
I typically leave the transmission in the car unless it needs attention as well.
Old Jan 13, 2013 | 07:09 PM
  #23
looked into motor after it was taken out. found balance shaft belt broken and timing marks were out about 90* so im sure there are alot of bent valves. im wondering if i should get this motor repaired and keep it for a spare since i also own a 200 accord. you guys think its worth it to fix it? thanks again for all the advice.
Old Jan 13, 2013 | 07:37 PM
  #24
Wazari's Avatar
What's the alternative? If you don't repair the motor were you thinking of replacing it with an used engine?
Old Jan 13, 2013 | 11:43 PM
  #25
Motor has been swapped. Was wondering if its worth fixing and keeping this one as a spare since there are a couple accords in the family.
Old Jan 14, 2013 | 08:49 AM
  #26
You'll have to judge the hassle of storing an engine. You'll have to keep the coolant passages & waterpump protected from corrosion (there's some steel stuff in there)
Besides, when you remove the head and see the extent of damage it might be bad-enough you don't want to save it.
curious126
Apr 17, 2007 02:22 PM
ncsgoofy
Sep 4, 2006 09:04 PM
GringoEJS
Jul 3, 2006 10:17 PM
nman
Jan 11, 2006 11:52 AM
Csparke
Dec 1, 2004 12:13 AM
