No fire 90 accord
Old Oct 30, 2009 | 03:02 PM
longdistance's Avatar
Default No fire 90 accord
Yes i'm a new member. This may be an old problem. I have a 90 accord, 4dr, auto. It has 140,000+ miles. It just died while driving on a busy street one day and has never fired again. Everything is still rotating and moving so timing belt looks ok. It turns over fine, just no fire. It has no fire at plugs or from coil. I have done all the suggested test. Relays check out ok, so does igniter. It is getting fuel. If all seems to check out ok where do i go from here? I have read where others have bought all these new parts and still don't get no fire. So if anyone has any suggestions i will listen. Thanks
Old Oct 30, 2009 | 05:09 PM
deserthonda's Avatar
u need to test the coil and igniter,,,,,,,,,,,,there are write ups in the DIY section ,,
Old Oct 30, 2009 | 05:34 PM
The other thing that you want to check is that the blk/yel wire at the coil has 12V when the key is in the II position.
Old Oct 31, 2009 | 09:34 AM
Default 90 accord wont fire
Thanks guys i will try your experience. I will let you know what i find. Thanks
chevmechanic
Apr 10, 2011 09:31 AM
ggr224
Jan 11, 2011 05:47 PM
uraceulose
Nov 6, 2010 09:32 AM
mrdennmann
Jan 19, 2009 01:54 PM
JohnTaurus
Sep 14, 2008 04:50 PM
