No gauges, wipers , blinkers , power windows n car stuck in park...
Old Feb 27, 2015 | 11:21 PM
georp's Avatar
Default No gauges, wipers , blinkers , power windows n car stuck in park...
Originally Posted by sumpump_1203
Alright, Fixed. Thanks a bunch everyone that had input.
Would u mind telling how u fixed this? I got the same problem... i tried to jump a dead window motor n now i have no gauges, wipers , blinkers , power windows n car stuck in park... checked all the fuses n nothing is blown... any help would b appreciated . ThNks
Old Feb 27, 2015 | 11:31 PM
That user has not been active on the forum since 2010.
What year is your car and model trim level (LX, EX, etc.)?
Old Feb 27, 2015 | 11:34 PM
georp's Avatar
2003 accord coupe. 4 cyl vtec.
Old Feb 27, 2015 | 11:44 PM
Which wires and location where the wires that you tried to jump?
Old Feb 27, 2015 | 11:48 PM
Under-dash Fuse No. 21 (7.5A) is probably blown. Check/re-check that fuse.
That fuse protects the Back-up light switch (M/T), Front passenger’s power window switch (EX, EX-L), Gauge control module, MICU, Hazard warning switch ('04-'05), Power window master switch, Relay control module, Shift lock solenoid (A/T), and Wiper/washer switch.
Old Feb 28, 2015 | 12:57 AM
georp's Avatar
A friend told me i should jump a non funtioning window motor . We ran a wire from the battery itself n a ground n were meant to to touch the motor plugs but somewhere in the process the jumper wires touched n it sparked a little but i inmediatly pulled em off so i dont think i caused a lot of damage here. But then i noticed most of my accesories where not working now. Blinkers, wipers, sunroof, windows, n shifter
Old Feb 28, 2015 | 01:08 AM
georp's Avatar
We checked all the fuses with a light tester n they all light up. I forgot to mention that rite after the jumper wires caused spark a chime came on. The chime that tells u the key is in the switch while the doors r open wasnt working before but now they are after the wires crossed
Old Feb 28, 2015 | 01:09 AM
georp's Avatar
But yeah i will recheck that fuse again tomorrow. Thank u!
Old Feb 28, 2015 | 09:19 PM
georp's Avatar
Problem solved! It was fuse # 21 indeed! Thanks much for the help!!
Old Mar 2, 2015 | 08:10 AM
Corvair's Avatar
I'm surprised that one fuse has that many functions.
natwood68
Feb 24, 2014 12:16 PM
bbybluluv87
Sep 5, 2013 03:30 PM
jdenny81
Jun 2, 2012 05:28 PM
th22ek9
Sep 8, 2006 09:07 PM
