No heat from center vents in auto mode
Old Nov 19, 2013 | 01:55 PM
1. If the view (map orientation) is set to display "North-up", then it just displays an "N" with an arrow above it pointing up. If the view is set to the 3D Map, a circular compass will display and moves, with the red part of the needle always pointing north.
2. The automatic suppose to have a dipstick. The CVT doesn't have a dipstick.
Attached Thumbnails No heat from center vents in auto mode-view-map-orientation-.jpg   No heat from center vents in auto mode-3d-angle-adjustment.jpg
Old Nov 19, 2013 | 02:03 PM
Dipstick is #11 in the diagram.
Attached Thumbnails No heat from center vents in auto mode-oil-level-gauge-atf-pipe-6at-1486632.jpg
Old Nov 19, 2013 | 02:20 PM
pspens's Avatar
It sure likes like #11 in the diagram is the oil dipstick. I looked carefully throughout the engine compartment; I could find no other dipstick.
Old Nov 19, 2013 | 02:29 PM
That part diagram is the transmission...
This other pic. is from another forum where someone finally found his auto dipstick, after he initially thought it didn't have one.
Old Nov 19, 2013 | 02:35 PM
Also, see this other image of the parts diagram, where it states ATF dipstick.
Old Nov 19, 2013 | 02:47 PM
pspens's Avatar
So is this all hidden from view by something else?
From p. 510 of my owner's manual. "6-cyinder models
Have a dealer check the fluid level and replace if necessary."
No picture of dipstick or location as opposed to the oil section where it actually shows the location of the dipstick as well as pictures of the 2 different type of dipsticks.
The 2013 Honda accord owners manual can be found online, if you don't believe me.
http://techinfo.honda.com/rjanisis/p...3/2A1313OM.pdf
Old Nov 19, 2013 | 02:50 PM
  #17
I know what the owner manual states. There is an ATF fluid dipstick. The transmission is on the left side of the engine.
I've been answering all your questions; but, you do not seem appreciative of the free help. So, good luck.
Old Nov 19, 2013 | 03:25 PM
  #18
pspens's Avatar
Red face
I'm sorry for being obstinate. I finally found it. It doesn't have a colored plastic ring that I'm used to seeing on older GM cars. It has a circular metal ring and is located below the radiator hoses on the bottom of the engine on the right side if you're facing the back of the car.
Why wouldn't Honda want the owner to check AT fluid?
The reason I was even wondering about the AT fluid is the annoying engine braking that I'm experiencing and which is apparently by design.
Is there any documentation on at what RPMs or speed the AT shifts into its 6 gears? It appears that there is a downshift (engine braking) when coasting and decelerating at 40 mph, 30 mph, and 20 mph.
Do you know if ECON mode has any affect on these shift points? My Pontiac GTP had a "Performance" button on the shift lever which presumably raised the points at which gear-shifting would occur.
Old Dec 5, 2013 | 12:07 PM
  #19
pspens's Avatar
Thought I would provide an update: Now that I've had a chance to drive my new Honda in cold weather I have to say the Automatic temp control works great! It is true that heat is not coming through the center vents, but the car warms up very quickly anyway!
Abhishek719
Nov 27, 2011 11:08 PM
klam24
Sep 21, 2011 06:21 PM
92Wahoo
May 18, 2009 07:35 PM
00AccordLX5spd
Feb 17, 2008 03:14 PM
dbriana
Jan 1, 2007 02:01 AM
