no keyless entry after replacing multiplex unit
Old Mar 13, 2014 | 06:41 AM
ndubg's Avatar
Default no keyless entry after replacing multiplex unit
2005 Honda accord ex, 4door. So i replaced the multiplex unit on the drivers side door now might keyless entry won't work. How do i fix this?
I plug my old on back in and the keyless entry works just fine.
Old Mar 13, 2014 | 09:06 AM
Why replace MICS?
MICS requires diagnostics similar to ECM, find code, and address code issues. You will need a shop manual to perform the diagnostics w/o special honda tool. check automanualsource.com for an download manual.
It may be as simple as new key replacement process, however this requires special tools that locksmith and Honda only have.
Old Mar 13, 2014 | 10:35 AM
After replacement of the door multiplex control unit, you'll have to reprogram the remotes. See post #8 in this thread link:
https://www.hondaaccordforum.com/for...78/#post320458
Old Mar 14, 2014 | 07:59 AM
ndubg's Avatar
Redbull-1: after watching the video in the link you provided i went and tried it. What i learned,from my experience, was that it does work but requires two keys to make this method work. One to have in the ignition and one to press the lock/unlock button. But again this method worked for me. thank you very much
NPaccord
Dec 7, 2014 05:36 PM
lmrj0030
Nov 3, 2012 09:24 PM
4cyl651
Apr 19, 2012 06:54 PM
Billyp
Feb 13, 2011 05:25 PM
bobs99coupe
Dec 22, 2007 11:25 AM
