No power in passenger window
Old Jul 20, 2024 | 12:16 AM
Asher412's Avatar
Default No power in passenger window
I drive a 2003 ex Honda accord. The passenger window was failing, but I also had dents n such in the door so I got a door from same model n generation from the junkyard. Installed it, power lock and light etc. working but not the window. Tried to test the terminal with volt reader and not reading any power. Please advise?
Old Jul 26, 2024 | 10:34 AM
Moved your post to gen tech help where you'll get more responses.
What parts from the original door were used in the replacement door? Did you use the original wire harness entering the door through the grommet, or did you replace that too?
Old Aug 5, 2024 | 05:02 PM
nomad2020's Avatar
did you chk the fuse??
OneLuckyGuy
Aug 29, 2017 01:30 PM
Terry s
Jun 24, 2013 05:38 PM
Mmhmm
Jul 1, 2011 10:27 PM
scagle777
Oct 6, 2008 04:22 PM
Jeff247
Apr 27, 2008 03:04 PM
