no start issue
Old Mar 2, 2013 | 05:26 PM
blumule's Avatar
Default no start issue
94 accord 2.2 vtec wont start. ive determined good spark , and main relay. pump turns on with key and gas flows to fuel rail. i cant really tell from there. regulator doesnt seem ruptured but i dont see evidence of gas reaching the cylinders. plugs are dry and piston tops seem dry. what would prohibit flow from fuel rail to cylinders. the injectors are ticking as motor turns over.
Old Mar 2, 2013 | 06:14 PM
How did you verify good spark? Have you checked for engine codes?
Old Mar 2, 2013 | 07:09 PM
blumule's Avatar
no engine codes. grounded plug at a bolt head and had a good strong blue spark. put a timing light on other wire and their firing,
Old Mar 3, 2013 | 09:51 AM
Is there any background info on the car? Just replaced X or did it just not start one day.
Try spraying carb cleaner in the TB - open the butterfly and give it a few good sparys.
Are the injectors getting voltage and ground? EDIT: I now see that you say injectors are "clicking"
Old Mar 3, 2013 | 11:44 AM
blumule's Avatar
ive cleaned throttle body. everything seems good, all i havent done is replaced plugs and a fuel pressure check. i pulled plugs and they appeared ok. they are bosch with about 3 years in the motor. i bought new ngk that ill be putting in this afternoon. ill report back. i did have a riding mower that wouldnt start. pulled the plug and grounded it . had what i thought a good spark. still woulnt start. i rebuilt the carb , adjusted valves, spent 2 weeks working on it. finally i bought a new plug on a last ditch effort and what do you know. fired right up like a brand new one.
Tony1M
Nov 6, 2023 08:29 PM
tzoromski1
Oct 4, 2012 10:24 PM
Cubeman
Jul 23, 2012 12:40 PM
zZHellBlazerZz
Jun 15, 2011 10:12 AM
art vandelay
Aug 2, 2010 09:29 AM
