no tach, or odometer
Old Jun 22, 2013 | 11:25 AM
phantomgrey92's Avatar
Default no tach, or odometer
ok so car runs nice, but i have no tach or odometer, speedo works fine. also its a 1990 dx engine tranny and ecu in a 1992 lx body
Old Jun 22, 2013 | 12:16 PM
Likely a problem w/ the gauge panel. VSS drives speedometer and odometer, so odo should work. I've had mine "stick" once or twice and had to restart by fiddling w/ the trip odometer reset and thumping top of dash.
Tachometer is driven by distributor ignitor signal output and may be possible that wiring was damaged during engine replacement. Blu wire from ignitor should send a pulsed voltage to the gauge panel. Circuit is not described, but I would expect 0-12V pulses.
96AccordEXV6
Jul 18, 2006 11:27 PM
imcameron
May 12, 2006 12:05 AM
iridebmx33
Apr 6, 2006 01:41 AM
brownstreak
Jan 8, 2006 03:19 AM
badmrb
Dec 6, 2005 03:16 PM
