no window or locks
Old Jun 16, 2011 | 07:20 PM
Tnhonda's Avatar
Default no window or locks
I have a 96 accord wx and none of the power locks work and now the drivers side window quit.. help
Old Jun 16, 2011 | 08:16 PM
Did you check the fuse for the door locks? Did the window stop working at the same time?
Old Jun 16, 2011 | 11:22 PM
But the other windows and door locks still work...Correct !?
Old Jun 17, 2011 | 05:24 PM
Tnhonda's Avatar
Default no power
yes the other windows still work, and no the door locks have never worked since I have owened 3mons.
Old Jun 17, 2011 | 05:35 PM
The index thread at the top of this form has a link for online manuals. Download a 94 shop manual and get a volt meter. Remove the driver's door panel. Check for voltage to the power door lock control unit (white wire) with the key in the II position. If no voltage, check the #38 fuse in the fuse box in the engine bay.
You can also unplug the two pin connector to the window motor and see if you get 12V to the window motor when you hit the switch to roll up or down the window (+ and - switch depending if you push up/down on the switch).
Old Jun 17, 2011 | 05:36 PM
Tnhonda's Avatar
where is the fuse for the locks?
Old Jun 17, 2011 | 05:51 PM
There is a fuse box near the windshield on the passenger side of the engine bay. #38 is a 20 amp fuse. See pic of fuse box. The pic is from the manual I suggested you download.
Old Jun 17, 2011 | 06:09 PM
Tnhonda's Avatar
sorry I am tyring to figure out wher the exactly that index is , I have looked and dont see index.
Old Jun 17, 2011 | 06:10 PM
Tnhonda's Avatar
sorry for the spelling, kids you know.
Old Jun 17, 2011 | 06:21 PM
The second post in this forum (gen tech help). It is stickied. Index to DIY Threads
Opballer
Feb 9, 2012 11:54 PM
ravenr106
Oct 21, 2011 06:08 AM
Stregamomma
Jun 3, 2011 08:52 PM
2006accordexl-passmirrorbroken
Apr 12, 2010 03:01 PM
mmazb3
Nov 26, 2007 03:16 PM
