Noise during acceleration only
Old Jun 5, 2018 | 05:51 PM
f1rlz's Avatar
Default Noise during acceleration only
Hey Guys,
I hear this odd noise while I am accelerating. It is not coming from the engine, it is coming from the bottom of the car. (as far as I can tell)
I do not hear this when the car is in park and I step on the gas.
This noise appears to be present when my car was parked outside in the sun and not so much when I had my car in the garage. (this may have nothing to do with it)
This noise can be described as a rustling or buzzing sound, I wish I could record it.
I am thinking it may be some kind of insulation around the exhaust pipe or the catalytic converter that has been rusted or "burned" up.
I know this is not much information but any help is greatly appreciated.
Thanks, F1.
Old Jun 5, 2018 | 08:07 PM
A common source for a rattle is where the heat shield bolts to the catalytic converter. The heat shield will rust or crack and can cause a vibration.
Old Jun 6, 2018 | 12:25 PM
f1rlz's Avatar
Thanks for the quick response, this was my gut feeling too.
So should I just take the heat shield off and forget about it? Or would you recommend replacing it? Thanks.
Old Jun 6, 2018 | 12:49 PM
Sometimes the shield rusts around the bolts; if so you can simply use larger fender-washers & put it back on. Or hold it with hose clamps.
There's several heat shields. If the rattling one is between the exhaust & the floorpan, I'd figure out some way to hold it in place (or replace it). (You don't want to set the soundproofing tar on fire while you're driving.)
mortuzahasan
Sep 30, 2014 06:43 AM
streetroc85350
Jan 22, 2013 09:49 PM
MessAround
Nov 1, 2012 05:01 AM
aushonda
Nov 22, 2011 10:38 PM
HondaAccord93
May 20, 2009 10:07 AM
