Noise while braking / turning after tire rotation.
Old Mar 10, 2014 | 11:29 AM
sona1111's Avatar
Default Noise while braking / turning after tire rotation.
Hello yet again.
I finished doing a tire rotation (only front to back) today and I how notice a rubbing noise while turning right and braking medium-hard. It sounds like it's coming from the front-right wheel well. I think this is happening because the back wheel was physically a little larger because it has less wear, though I could be wrong. Anything I can adjust over there to stop the noise / inefficiency?
thank you as always.
Old Mar 10, 2014 | 01:54 PM
Are tires OEM size? If yes, then wear is not the issue. Most likely is a brake issue; pads worn out?
Old Mar 10, 2014 | 02:38 PM
sona1111's Avatar
I have not checked the size, is the owners manual or a hanes manual a good guide stating the OEM size?
I had brake rotors replaced about four months ago and the pads were also in the receipt but I did not oversee the work being done.
Derekhhh
Oct 13, 2013 03:14 PM
Pajamarama
Jul 12, 2012 11:18 PM
ZionsWrath
Jun 13, 2010 11:14 AM
HondaAficionado
Sep 22, 2009 06:53 PM
mpc8240
Sep 26, 2007 08:41 PM
