normal?
Old Aug 18, 2011 | 05:46 PM
accord99's Avatar
Default normal?
Took exhaust man off 2.3vtec. And all ports fairly clean with white residue on valve stems except the one with the egr port hole. Is this normal. Caked with looks like black burnt oil. Is this a prob?
Old Aug 18, 2011 | 06:24 PM
The EGR passages can get plugged up with carbon buildup. It is pretty common on hondas. Carbon builds up over time in the passages.
Clean as much out as possible.
The carbon buildup can get pretty bad on the port in the intake manifold upstream from the EGR. This will usually set an engine code.
Old Aug 18, 2011 | 07:22 PM
accord99's Avatar
The intake side is clean. The passage that runs from the exhaust port toward the egr is open. Just didn't know if all that black build up was normal in that one port.
ozman05
Jul 10, 2007 10:14 AM
91boz
Nov 29, 2006 03:35 PM
dbrs0821
Sep 17, 2006 11:58 PM
khedairys5
Sep 16, 2006 08:43 PM
notamechanic
Aug 16, 2006 08:54 AM
