Not Runnin rite
Old Apr 17, 2011 | 06:55 PM
Jsteves89's Avatar
Default Not Runnin rite
Is it possible to run a 97 f22b1(OBD2) on a 95 f22b1 ecu(OBD1). I swapped my f22a which i blew up with a f22b1 from a 97 not knowing the difference form the obd1 to obd2 ... the car runs its just running on three cylinders and i cant for the life of me figure it out????? If neone culd help that wuld b great
Old Apr 17, 2011 | 09:33 PM
The set of sensors on the engines are different. You should probably swap the sensors & distributor from your old engine. The alternative would be to use the 97 ECU along with the newer wiring harness (lots more work).
MoDawG
Dec 10, 2009 07:00 AM
imjrk
Sep 28, 2008 10:06 AM
jipmpizzle
Jul 5, 2007 03:40 PM
Monicalovesaccord
Oct 23, 2006 12:06 AM
fperezal
Jun 14, 2006 05:03 AM
